Kenetico 60 water discharge
B Skipper
I have a 20 yr old model 60 that does not stop discharging water I have taken the head appart and cleaned it, but problem still persists any suggestions
Akpsdvan
Alaska
Not knowing a lot of the Kinetico units, I would say that the valve that is to close when in service and not cleaning the other tank is worn and not seating right or that the piston that should be closing is not or it to is worn.
You might be able to find either a used control head that some one is selling or get the part from some Kinetico dealer..
Skip Wolverton
Ocala, Fl
www.servicemagic.com
With a phillips screwdiver, push down on the center piece of the clear plastic top and turn clockwise slowly. If the water stops, the valve is not advancing to the off position. If not, a drain seal is at fault.
B Skipper
Water does not stop, would the drain seal be one of the 4 bigger plungers or could it be a o ring on the pistons?
Akpsdvan
Alaska
Might you be talking about a valve like this one?
Akpsdvan
Alaska
This one has orange and 2 on the dial that is under the clear.
Yours?
PM if you would like.
