Results 1 to 13 of 13
Thread: No soft water after filter change on a Kinetico
    DIY Junior Member Tony Foran's Avatar
    Feb 2010
    mi
    Default No soft water after filter change on a Kinetico
    I swapped out the pre filter and now I'm only getting water if the softener is by-passed. Do I have air in the system? What I'm I missing?
    Thanks for any help,Tony
    There is a plastic rocker inside the valve that, if broken, will not allow water thru the unit. I have a picture of it but don't know how to post it.
    Feb 2010
    mi
    Quote Originally Posted by Skip Wolverton View Post
    It worked fine before the filter change but now I only have water on by-pass. I could have damaged the valve somehow?
    Dec 2009
    Alaska
    What kind of bypass for the kinetico?
    Did you bleed the air out of the pre filter after the filter change?
    Previous member
    Jul 2009
    North of the Mason dixon Line
    Skippy, you have to go advanced so you have all the posting options. There is a thing looks like a paper clip, that's for attaching photo's.
    Dec 2009
    Alaska
    Is that plastic part that easy to break?
    Is it one of them that if you look at it wrong it breaks?
    Feb 2010
    mi
    Quote Originally Posted by Akpsdvan View Post
    No, I did not.
    Feb 2010
    mi
    That did it! Thanks a lot for the help.
    Dec 2009
    Alaska
    If this was in Alaska I would be saying
    Strange things happen in the land of the midnight sun.
    Why a ball valve is not used before and after a pre-filter is still a strange thing to me.
    Yes the plastic rocker can break at anytime. When broken, it causes both pistons to close shutting off the water supply. The rocker is the ones in the upper right side of the pic (small piece). Thanks for the help.
    Dec 2009
    Alaska
    Brake at ANY time?
    Och....
    Is it a fail safe idea?
    Why would some thing that could cause that much trouble still be in use?
    Brake at ANY time?
    Och....
    IIRC when it switches tank, the rocker forces the opposit piston to close preventing water flow from the tank in regen. They do break easily with age.
    Dec 2009
    Alaska
    Every unit has its weak point..
