Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Fleck 2510 Salt Dose
    DIY Junior Member qpm's Avatar
    Feb 2010
    Alaska
    Default Fleck 2510 Salt Dose
    Where do you adjust the salt dose on a Fleck 2510? This is the standard model not the digital SE or STX models. It does not mention how to adjust salt setting in the owners manual and I have only found info on how to adjust the 5600 salt setting online. Any help is greatly appreciated.
    Feb 2010
    Alaska
    The above attached document is the manual I mentioned having. I do not see anywhere that shows how to set your salt dose or efficiency in the manual. Any help would be greatly appreciated.
    DIY Senior Member Bob999's Avatar
    Jul 2009
    Pennsylvania
    See page 8 of the manual Peter posted. Times for the cycles are controlled by pins and gaps between pins. Each pin (or hole) in the timer wheel is either 1 or 2 minutes, depending on the specific timer. The salt dose is controlled by the length of the brine fill in minutes times the flow rate of the Brine Line Flow Control (BLFC) and taking into account that 1 gallon of water dissolves 3 lbs of salt. There is typically a sticker on the valve that lists the size of the BLFC--the most common value is 0.5 gallon per minute. If you have a .5 gpm BLFC and you want a 6 lb salt dose then you would set the time for brine fill to be 4 minutes (4 minutes x .5 gal per minute = 2 gallons of water which equals 6 lbs of salt).
    Dec 2009
    Alaska
    Quote Originally Posted by Bob999 View Post
    Page 8? mine has page 7, the one that shows the back side of the timer assembly..
    That said it all...
    First pins are for Backwash
    Spaces are for brine draw/rinse
    Second set of pins for Rapid Rinse
    Second set of spaces for Brine refill
    Third set of pins for Stop..
    Feb 2010
    Alaska
    Thanks Bob. I probably would have never figured that out. On the Fleck 5600 it looks like there is an actual salt dose setting on the back of the controller. I thought there might be a similar setting for the 2510. Guess not. It appears page 7 and 8 of the manual have the same exact print as far as I can tell. Weird.
    Dec 2009
    Alaska
    Depends on the print run of the manual.
    Units with the timer assembly that the 2510 have are great to customize for the water and usage of the system.
    I normaly have 6 pins for the backwash, 25 spaces for 50 minutes on the brine draw/rinse then 3 or 4 pins for the rapid rinse then either 2 or 3 spaces for brine refill, some times I will do 4 spaces but always end with 2 pins.
    Not that hard to move pins around, just unplug unit, unplug meter cable if it has one from the meter dome and then remove the timer wheel, make the pin changes and put every thing back together again.
    DIY Junior Member wiz561's Avatar
    Apr 2011
    Chicago
    Quote Originally Posted by Akpsdvan View Post
    Hi! I know it's been a long time since the reply to this, but Akpsdvan, I was wondering how you know your recipe for setting the pins. Is it documented anywhere? Just personal experience?
    I have a feeling that I have to tweak mine, and before I start messing around with it, I'd like to know how you came up with the pin setting.
    The pin settings are dependent on the size of the softener or filter, what type resin or media and your water quality. So give us that data and we can help with pin settings.
    Apr 2011
    Chicago
    Default thanks
    I've done it before, but now I'd really like to get these settings perfected. All I've really adjusted in the past was the front dial. I think I have to tweak the back one because I believe it's stock, since it's the same as what other people on the net had. Here's what I currently have set:
    Backwash: 10 minutes
    Brine Cycle: 60 minutes
    Rapid Rinse: 10 Minutes
    Refill: 12 Minutes (.5 gpm)
    Here are my results...
    Fleck 2510 metered softener
    64k grain capacity
    12x48 resin tank
    2 cubic feet high capacity resin (I believe here's the info to it. http://www.ohiopurewater.com/shop/fi...lsencation.pdf)
    15x17x36 rectangular brine tank
    20 micron flowmax filter
    Water results:
    Iron: My water test said '0' when I used a kit. Didn't send it in. However, on my filter, after a few months, there's orange on it. Some rust stains in the toilet if I don't clean them every two weeks or so. City water report says 0.046 Highest Level Detected, range is 0-0.046, and MCL is 1.0ppm.
    Total Hardness: (as CaCO3) is 35 GPG
    Chlorine: 0.4433 - 0.6212 ppm
    Haloacetic Acids (HAAS) 1.1 - 1.1 ppb
    Total Tihalomenthanes (TTHMS) 8-8 ppb
    Barium (I think; it says arium): 0.016 - 0.022 ppm
    Flouride: 0.84 - 1ppm
    Manganese: 6-7ppb
    Nitrate: 0-0.97 ppm
    Selenium: 1-2 ppb
    Sodium: 37-38 ppm
    Zinc: 0.007-0.022 ppm
    Uranium: 2.662 - 2.682
    Gross Alpha exluding radon and uranium: 0-0
    Combined Radium 228 - 0-0.559
    Beta/photon emitters: 4.2
    Water Usage: I failed to mention how much water we used. It's two people now, but will be three soon. We use the average amount per person per day. I believe it's 75 gallons per person.
    Thanks for the info. As I said, I've tried to understand the equation to this, but I believe it's more experience (and some voodoo). Now that a few months have gone past, I'm getting tired of the rust stains in the toilet, which leads me to believe something's not adjusted correctly with the softener. If somebody can post the equation and results, that would be most excellent.
    Thanks,
    Mike
    Last edited by wiz561; 11-09-2011 at 03:04 PM. Reason: added info for resin, water usage, and fixed the water test results for the specific well.
    Nov 2010
    Maine
    You are going to have issues with this equipment as it is very much undersized for 3 people and 75 gallon per person per day.
    You can get a pretty good estimate here http://www.qualitywatertreatment.com...ner_sizing.htm
    Just plug in your numbers and you will get a better idea of your needs.
    Apr 2011
    Chicago
    Thanks for the response, but I don't understand why you would think what I have is undersized. When I visit the web page and put in the information (3 * 75 * 35 +1) = 8550 grains per day. According to the matrix, 6800 to 9100 is 64k grain capacity, which is exactly what I have.
    Thanks, but just confused.
    Nov 2010
    Maine
    Yep, sorry late night, wrong thread on the wrong forum, brain cramp
    Apr 2011
    Chicago
    No worries, that's a-ok. I'm new to this water softening stuff and trying to figure it out. I'm easily confused, and when I saw that, I got confused.
    Thanks though for the response!
    Mike, click the link in my signature and do your math by hand to come up with the K of capacity you need and then adjust the number of minutes of refill to get the salt dose to give you that K of capacity. The rest of the numbers are OK for a 20 cuft softener. I would use 60 gals/day/person and one days worth of total grains as the reserve.
    The orange color in a months old disposable cartridge filter is normal but, for 1 ppm of iron you convert it to 4 gpg and add that to the gpg of hardness. The discoloration in the toilet may be from a galvanized nipple etc. after the softener. You may want to run some Iron Out through the softener every two months or so.
    BTW, 60 K is all you will get out of a 2.0 cuft of regular mesh resin, and that "high Capacity" term is hype. To get 60 K you need to use 30 lbs of salt per regeneration. Your 48" tall tank is 4" shorter than the normal size for a 2.0 cuft of resin. that can cause insufficient backwash because the freeboard space is reduced. Freeboard is the empty space above the top of the resin and the top of the tank, not including the dome shaped area.
