I have a new problem with my well pump. It turns on about every minute for aproxx. 15 seconds. I put a pressure gage on a utility sink faucet and see the gage fluctuating up and down between 35 and 50 psi. How can i figure out where the problem is?
- Tank waterlogged? "Well-X-Trol" How do I check?
- Check valve stuck? Where is it and how can I test it?
- Pressure switch? testing procedure?
- Broken/leaking pipe between house and pitless adaptor? G-d I hope not, how can I tell?
All help is welcome. I am afaid the pump will burn up.
Thank you,
Marty
Thank you,
Marty
