Results 1 to 5 of 5
Thread: Dryer vent/ducting
    DIY Senior Member DIY's Avatar
    Dec 2006
    Florida
    Default Dryer vent/ducting
    Hi all,
    Does anybody here have any first hand experience with periscope type duct that is square in shape,and measures 2" x 6" for limited space installations, and is said to work as well as the standard 4" round duct?
    Thanks to all!
    ALthough they are a little flimsy, they seem to work ok. I have not seen any actual test results about air flow. Be sure to tape all joints with foil tape, or you will "leak" lint.
    Yakima WA
    The only ducting I am aware of the should be avoided is the flexible tubing. That's because the ridges inside catch lint and eventually create a fire hazard.
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    We have sold them for years with never a problem. Do tape the joints.
    DIY Senior Member Master Brian's Avatar
    Nov 2008
    Kansas
    Does that hold true if I use about 4' of the flexible aluminum(?) stuff to make a connection to rigid dryer tubing. It was used to simply a sort of complex bend and make connection to the dryer easier. Most of it will eventually be buried behind a finished wall, I'm guessing it should be replaced with rigid pipe. Sorry for the intrusion...
