ALthough they are a little flimsy, they seem to work ok. I have not seen any actual test results about air flow. Be sure to tape all joints with foil tape, or you will "leak" lint.
Hi all,
Does anybody here have any first hand experience with periscope type duct that is square in shape,and measures 2" x 6" for limited space installations, and is said to work as well as the standard 4" round duct?
Thanks to all!
The only ducting I am aware of the should be avoided is the flexible tubing. That's because the ridges inside catch lint and eventually create a fire hazard.
We have sold them for years with never a problem. Do tape the joints.
Does that hold true if I use about 4' of the flexible aluminum(?) stuff to make a connection to rigid dryer tubing. It was used to simply a sort of complex bend and make connection to the dryer easier. Most of it will eventually be buried behind a finished wall, I'm guessing it should be replaced with rigid pipe. Sorry for the intrusion...
