Results 1 to 7 of 7
Thread: 1.5" or 2" nails for hardwood install? Or staples?
Hybrid View
    DIY Junior Member 1320ms's Avatar
    Oct 2009
    Maryland
    Default 1.5" or 2" nails for hardwood install? Or staples?
    Installing 3/4" solid wood hardwood flooring over 1/8" DreamHome insulayment onto 23/32nd OSB subfloor
    My guy at the flooring company tells me for solid wood to use nails, he wasnt sure what size though
    Reading online other people say staples have a stronger hold
    If I nail it, I've gotta choose between 1.5" or 2" nails, from reading I understand that I dont want the nail to penetrate all the way through the subfloor, so I'm thinking a 1.5" nail would be best, but then lumber liquidators (where I bought the underlayment) is telling me to use a 2" nail
    Does it even matter? Seems everyone has their own opinion on nailing vs stapling, but if I do go nails, 1.5" or 2" which will be better?
    Plumber jimbo's Avatar
    Is this a nail straight in, or throught the tonque at a 45? I think I used 1 5/8" nails on my oak tonque and groove, and as I recall, 1 3/4 or 2" was considered "standard" but my floor is 3/4 oak on 3/4 plywood on lightweight concrete, so I REALLY did not want the nail to penetrate the subfloor. This floor has been down now since 1990, and looks great, so thost nails did the trick.
    Oct 2009
    Maryland
    Through the tongue at 45, again, figuring out if I'm going to staple or nail, so I'll either be using a bostitch MIIIFN or MIIIFS
    A 1 nail on a 45 has a total depth of approx. 1" vertically down from the head. Figure 1/8 for the foam, 3/8 for half the thickness of the hardwood, that only gives you 1/2" into the subfloor. A 1 5/8 or 1 3/4 long nail or staple will still not penetrate and will give you that much extra length of grip.
    DIY Junior Member gluecan's Avatar
    Aug 2009
    Minnesota
    use 2 inch i do and have for 30 years staples are better in most wood flooring
    Oct 2009
    Maryland
    So then, nails or staples?
