Thread: Venting a toilet in the Wall behind the toilet but the drain is across the room?
    never ending repairs Weekend DYI's Avatar
    Feb 2010
    Seattle
    Default Venting a toilet in the Wall behind the toilet but the drain is across the room?
    Can anyone tell me if I can add a vent only behind the Toilet and use a 3" ABS Sweeping 90 TEE to do so? The actual drain is 9 feet away across the room. See my attached Drawing.
    Your question is confusing. The pipe going up the wall behind the toilet is its vent. The other pipe will only be a legal vent if your inspector would approve it. Some would, but many would not.
    Feb 2010
    Seattle
    So you are saying to vent behind the toilet like this is ok, even though to do it, I have to tee at the toilet flange?
    Jan 2008
    Your picture is not clear as to how exactly you plan to make the connection.
    The vent cannot run horizontally behind the toilet so a tee would not work. A wye would work, depending on exactly how the connections are made.
