Results 1 to 8 of 8
Thread: Aluminum Pipe Wrenches
    Jun 2009
    Canada
    Default Aluminum Pipe Wrenches
    Thoughts or opinions on these?
    I think beyond the weight savings, they'd be great because they wont rust if you end up working in a ditch or out in the rain.
    Previous member
    Jul 2009
    North of the Mason dixon Line
    They are twice as expensive to do the same job. I think the small ones are a wste of money though if you carry a bunch in the tool bag they sure save some weight. When we get into the 2' range though they are a lot easier on the muscles.
    Plumber Cass's Avatar
    if you use them all the time that is what you want...I haven't found any I like as well as Ridgid brand...the ones from china are junk...
    Previous member
    Jul 2009
    Reed makes a pretty good one and so does Lennox.
    Default lumnum
    The new ones are similar in size to the forged steel ones, but I am not sure if they will take the same beatings. The original ones were so much bulkier that we never used them.
    Previous member
    Jul 2009
    From experience I can tell you that if you put a big cheater bar on an 18" aluminum the handle snaps clean off with disasterous results. Steel bends.
    Jun 2009
    Canada
    Quote Originally Posted by Peter Griffin View Post
    I'm sure it says not to use a cheater bar on the tool anyways.
    Previous member
    Jul 2009
    Yep, reading dem directions can sure save you a broken tool and 6 stitches to boot (:
