Results 1 to 6 of 6
Thread: Whole House Surge Protect Sub Panel
    DIY Junior Member
    Feb 2010
    escondido,ca
    Default Whole House Surge Protect Sub Panel
    I am finishing adding a new sub-panel for a customer.
    The main panel has no more room in it and is flush mounted on the exterior of the house.
    I want to add some surge protection. Would my installing a whole house surge protector at the sub-panel be much different than at the main?
    The sub is mounted back to back to the main and is fed w/ #8s.
    TIA
    Bob
    Jun 2007
    North Carolina
    If it is wired into a remote distribution panel then it wouldn’t be whole house would it?
    Uhhhh....that was the question.
    If it's wired into the main panel thru a breaker it protects everything on the bus....right? Does iot protect anything downstream on a sub panel? If so, would it not do the same thing in reverse since th sub and main are connected?
    I have no idea. I was hoping someone would know.
    Jun 2007
    North Carolina
    Quote Originally Posted by 220/221 View Post
    Yes it will take the surge no matter where on the system it is installed
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    IIRC the instructions call for the surge protection to be as close to the main breaker as possible. A subpanel certainly would not meet this.
    A subpanel certainly might meet this.
