Results 1 to 14 of 14
Thread: Is this water closet drain vented properly?
    DIY Junior Member mjsmith0's Avatar
    Dec 2009
    Los Angeles, CA
    Default Is this water closet drain vented properly?
    Here are a couple pictures of the plumbing for my water closet. (One is dry fit and the other shows it installed). Does this look like it's vented this properly? (The vent pipe will extend 4-5' farther up before it turns.)
    Thanks in advance!
    Jan 2008
    A vent cannot run horizontally until it is a minimum of 6" above the flood rim of the highest fixture.
    Plumber jimbo's Avatar
    Unfortunately that is a VERY BIG NO. That fails inspeciton for the very real reason that such a horizontal vent would very soon be clogged with waste.
    Dec 2009
    Los Angeles, CA
    Darn, I was afraid of that. Thanks for saving me from a big mistake. I got the idea of venting it this way from the a DIY webpage:
    http://www.diyadvice.com/diy/plumbin...in-vent-lines/
    I guess it's wrong?
    Mary
    DIY Junior Member jc60618's Avatar
    Dec 2009
    Chicago
    The last illustration would pass inspection in Chicago, I dont know about your area.The pictures you posted before wouldnt because you had those two fiitings raising the quarter bend above the vent. But like I said this last illustration would pass in Chicago. We often vent suspended toilets, p-traps or showers this way.
    Dec 2009
    Los Angeles, CA
    Gotcha. It makes sense to me now. Probably should have realized that before. Thanks!
    Jan 2006
    Rosedale, Md
    Smile
    Quote Originally Posted by mjsmith0 View Post
    I guess it's wrong?
    Mary
    Under the UPC you can run a flat vent the way it's shown, you just have to add a clean-out on the vent where it comes up in the wall.
    Dec 2009
    Los Angeles, CA
    Default Another idea
    How about this? Would this work and pass inspection? (The sanitary tee is rotated 45 degrees around the horizontal.)
    Previous member
    Jul 2009
    North of the Mason dixon Line
    Nope, 2 reasons. can't lay a san tee on its side and your vent off the back of it is still flat. Re-think the whole thing. What code are you under? If it's IPC your vent to water closet distance is unlimited and it may be far better to wet vent the whole lav throught the lav.
    Dec 2009
    Los Angeles, CA
    Default One last try
    Here is a variation on that design that would fit in the space I have. It is somewhat like the design I found on DIY site I showed above, but with a twist (literally!) I wonder if its too much of a pretzel?
    Thanks everyone for your patience and help while I try to figure this out!
    Previous member
    Jul 2009
    Nope, you still have a flat vent there. All vent piping must rise vertically.
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    Its being wet vented from what I see. The only issue that I see is that you have too many bends before the vent
    Dec 2009
    Los Angeles, CA
    Quote Originally Posted by Peter Griffin View Post
    If the water closet distance is unlimited, can I do something like this. (This is a picture that show more or less how the whole system is designed.)
    Previous member
    Jul 2009
    Krow, that looks like a clean out there, not a san tee.
