Results 1 to 2 of 2
Thread: Dripping Delta single handle shower head
    DIY Junior Member
    Feb 2010
    SD
    Default Dripping Delta single handle shower head
    The dripping in my shower is about to drive me nuts. In the past 4 years it has been repaired 3 times by a professional plumber for the dripping and the inability for the water to get really hot. The wall on which the controls are mounted can be accessed from behind, so I am ready to cut a hole and replace the entire assembly. Before I do that is there anything that should be checked to make sure the Delta cannot be repaired? How big should the hole be to remove/replace the whole assembly?
    Plumber jimbo's Avatar
    A Delta can virtually ALWAYS be repaired, so we would need to see some pictures of your valve to recommend how to proceed.
    If you decide to replace it , many of us would recommend a Delta R10000 valve.
    Start with approximately a 12" X 12" hole. The hole size can then be refined to faciltate a neat patch.
