Thread: Dishwasher not draining
    Default Dishwasher not draining
    Neat forum. So, for my first post I will ask for help. Two years ago I installed a Kenmore dishwasher and it has worked great since day one. It was not a hard install as I only replaced an existing aged dishwasher. Now after two years, the dishwasher will not drain completely. There is usually about two inches of standing water in the bottom. The drain air gap has not overflowed. When I use the "drain" cycle it still will not drain completely?? Any help would be greatly appreciated.
    KPD007
    One thing to check is the entire drain hose, all the way from the DW. Any kink, or internal clog, can cause problems. Otherwise, it may be the pump.
    There is an excellent appliance repair forum at http://homerepairforum.com
    Jul 2005
    Marin Co. Ca.
    Default maybe
    a chunk of meat in the hose?
    Apr 2005
    If it is worth your time I would take the bottom pull out grate, inspect the screen inlet in the center of dishwasher. If there are screws (most likely) then unscrew them and remove the inlet screen. Even though those holes are small, sometimes weird stuff gets past the screen. Shrimp tails, toothpicks, rabbit grass from easter are just a sample of some things that I have seen make it through the hose and clog an air gap.
