Results 1 to 10 of 10
Thread: Moen rough in valve 3320 3330
    DIY Junior Member Ysbelman's Avatar
    Feb 2010
    Chalotte NC
    Default Moen rough in valve 3320 3330
    I need some advice, i may have screwed up the way i positioned my rough in. This unit is by Moen, used for shower head and hand held spray. I'm attaching some pictures to show what is wrong with it. Basically the bottom handle is way out and has too much clearance, while the top nob bottoms out. These valves are pull/push, plus left/right. So when i push the top all the way in, it bottoms out on the trim piece I installed it somewhat to the spec, With the "plaster" plate, the unit is 3/8" inside the tile. Which is supposedly an option for thin walls (installing behind). The valves a sort of plumb, not perfect, but close. Any advice? Do i need to break the wall behind and redo? Name:  photo 3.jpg
Size:  36.5 KBName:  photo 4.jpg
Size:  36.3 KBName:  photo 2.jpg
Size:  42.1 KBName:  photo 5.jpg
Size:  33.8 KBName:  photo.jpg
    Feb 2010
    Chalotte NC
    another pic before cement board and tile: Name:  IMG_0227-1.jpg
    Re. the bottom handle; There is NO SUCH thing as "too far out" as far as the manufacturer is concerned, unless the trim plate will not go on and touch the wall. It may be "too far out" as far as your wishes are concerned, but that is a personal preference, not an installation parameter. By ositioning it at that depth in the wall, and not installing it plumb you have created the situation, and unless you reposition the valve, you will need an "extension kit" which will move the handle an additional inch formward. Still not "too far out", but it might affect your sensibilities. This is partly the reason that plumbers prefer to install the valve farther forward, rather than deeper into the wall, regardless of how the customer saw it on a display board created by a designer who was only concerned about how it looked, NOT how it could actually be installed. But then, I try to NOT have the customer buy Moen tub/shower valves whenever possible because they have the "worst" handle designs, other than the crystal teardrop one, I have ever seen.
    Feb 2010
    Chalotte NC
    HJ, u made me feel a lot better!!! thank you. My thoughts exactly on two points: handle design is of minutest of tolerances - for "rough in" plumbing. Two, i wish i wasn't my own customer I do want to get this sucker to "show room" look&feel, to validate $700 i spent on this headache. Question about this 1" extention tube. I called the Moen people and they told me the extension tube is not machinable, but when i look at this pic, i think it could be. Especially the top one. The bottom one, i think i can file the original one down as well. Top needs 5mm extension, bottom needs 5mm reduction.
    Name:  moen extension tube.jpg
    This problem is notoriously common with Moen shower valves. Try doing a Google search for "Moen sticks out too far."
    This thread may or may not be of value to you:
    http://www.terrylove.com/forums/show...ng-out-too-far
    If you file things down, you probably won't like the results. SOme of the stuff is plated plastic, and you'll end up with it peeling off. Regardless, you'll expose the internal base metal, if it is metal, which will cause it to corrode sooner. You need to try to get the thing plumb with the wall so they are even.
    Feb 2010
    Chalotte NC
    good news.. i think - for me and for Moen. But i need confirmation from real plumbers. Posting pictures, because there ain't a way to describe. The top knob doesn't push/pull but 4mm when it's free of any trim, it only rotates right/left. Which leads me to a conclusion - it's not supposed to move right left and my installation (first time at plumbing) was right, and plumb enough. Does a user's manual exist for this unit? Got the installation-by-picture pdf, but an actual explanation of how this thing works!?
Size:  42.9 KBName:  photo3.jpg
    DIY Member export!'s Avatar
    Oct 2009
    Ontario, Canada
    Did you alreay cut through the rear wall and remove the 2x4 support?? You should be able to manipulate it into perfect position now.
    IANALP
    (I Am Not A Licensed Plumber)
    Feb 2010
    Chalotte NC
    Yep! doing that now. Hands dirty, but grinning!!! I have more clearance than i thought. Thanks Export!
    Oct 2009
    Ontario, Canada
    Good for you. You got lucky with access behind the valve rough in. That tile job looked pretty nice. It's worth triple-checking a valve for perfect orientation and mocking up your sheeting/tile/mastic thickness if you are unsure. I know exactly what you mean about the playskool looking Moen picture-directions. I used to pull my hair out trying to rely on them until I learned enough to not need them.
    IANALP
  1. Moen 3330 / 3320 valve instructions
    By teah2006 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-31-2012, 09:13 AM
  2. Moen 3330 Valve Help
    By crosby1 in forum Shower & bathtub Forum & Blog
    Last Post: 02-11-2008, 04:00 AM
  3. Problem with Moen 3330 Valve
    By Guest in forum Shower & bathtub Forum & Blog
    Last Post: 06-20-2007, 03:49 AM
  4. Moen 3320 rough-in confusion
    By Plumb Crazy in forum Shower & bathtub Forum & Blog
    Last Post: 04-16-2006, 05:16 PM
  5. Moen 3320 rough-in confusion
    By Plumb Crazy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-25-2005, 08:48 PM
