Results 1 to 7 of 7
Thread: Pop Up Drain in Vessel Sink Drains Slowly
    DIY Junior Member
    Jan 2010
    Colorado
    Default Pop Up Drain in Vessel Sink Drains Slowly
    I have a vessel sink that drains slowly. I figured it was the lack of positive pressure. I have a pop up drain with just two small oval openings for water and air to go through. Any recommendations on how to get past this problem on a sink with no overflow? Thanks.
    Can you modify the popup so it rises higher. Most popups are a disc that move up and down. How about a picture of the installed drain.
    Plumber Cass's Avatar
    many of the older designs can't be raised more...some of the pop ups are on the rod wrong by 180 degrees...
    DIY Junior Member
    Jan 2010
    Colorado
    Default Pop Up Drain pictures
    Here is a picture of the relatively new drain from inside the bowl and below the vanity. It looks like I can raise the threads.
    that's a common problem. it's not a regular popup. they tend to drain slower than a normal lav sink drain. I have even seen the slam shut when draining a full sink.
    DIY Junior Member
    Jan 2010
    Colorado
    Thanks for everyone's input. It's too bad if we have a drain with that problem. Does anyone have a recommendation for a replacement pop up drain? Thanks.
    If you don't plan on filling it, you could try a grid strainer.
