Results 1 to 3 of 3
Thread: Plumbing woes....main line.
    DIY Junior Member ferfer's Avatar
    Feb 2010
    Barnesville, GA
    Default Plumbing woes....main line.
    I randomly found this forum and started reading some good information here. I have had the same problem several times for the past 2 yrs now.
    Let start with the info. 2 story house built in late 1800's and added onto once.. 1 bath upstairs, 1 down. on crawl space however main line and vent stack runs along outside of house and then into ground. cast iron pipe with some pvc spliced in(not by me). sewer system.
    so 3 times in recent years our plumbing has become awful. our plumbing will just cease to work. toilet downstairs will not flush down....will sometimes back up into tub downstairs. tub down will go down slowly or not at all and will make toilet down gurgle along with toilet up gurgle and kitchen sink down gurgle. wash machine when draining will back up into down bathtub. on this recent bout of trouble the kitchen sink will not go down either.
    Each time i have rented an auger to run through main line to sewer connection. each time it has made the plumbing work. this last time though it only worked for several weeks before doing the same thing. I have gotten some small roots out but nothing big and there are not trees running along where line is. there are stumps however.
    I really believe the vent stack is clogged or the pitch to city connection is not enough or have some failing spots in the old cast iron pipe.
    got a quote of $400 to just run a camera through the pipe but would rather just spend the money and replace all the cast iron with pvc and achieve better pitch in process.
    questions are about my theories and another is to whether I can connect main line to city sewer? If it is connected at curb I know I can do it. and i know i can dig the trench and run the pipe myself as I have been in the landscaping industry for a long time.
    sorry for long post. wanted to be as specific as possible.
    thanks for any help or recommendations.
    Plumber Cass's Avatar
    Nov 2005
    You may have a partial clog, roots, or some other problem, have it snaked professionaly and then cameraed...there is one Rooter company that may camera it for free if they snake it...not much else to do...since you don't know what the problem is...
    You do not even have to have stumps for the roots to continue creating problems for 20 to 30 years after the tree is removed. We do not know if you are using the correct auger/snake machine and components. Once roots become a problem, one or two years between recurrances is about correct.
