Bird Doo Head
Hi All
A family member presented me with an interesting problem he is working on in his house. I was not sure what I was about to tell him was correct, so i thought I'd pass by all of you experts for the real answer. (if you don't mind):
He has, in his old, old home, two island bathtubs. The walls for the tubs with the faucet & drain are only about 2" taller than the tub rims. (They are not free standing tubs. they have aprons) the faucets are deck mounted with flex hose showers. the tubs are in the "middle" of the room.
His drum traps froze and broke before he bought the house. he installed 2" P Traps on the tubs. Now, when a toilet flushes or a full tub is emptied, of course the traps gurgle and try to suck dry. I told him I thought they needed to be vented. But, in the middle of the room- how?
The best guess I came up with was to run a vent from just after the trap to the wet wall (about 4 feet away) and up, above the third floor bathroom fixtures and tie into the vent. But, the problems I see are that
A) The vent will run horizontally in the floor under the bathroom to the stack. An accessible clean out can be placed behind the access panel in the short wall. Somehow, I don't imagine that is to code, but I think it may be better than no vent. An AAV would be below the flood rim, as the wall is about tub rim height.
B) The vent would "tee" in to the tub drain almost at the point the drain meets the stack. (The stack fitting is a 3x3x3x2 Toilet, & Both Tubs) The lav sink and toilet are not vented either. but those are easy.)
I attached a drawing to help clarify. Black is existing and red is planned.
What do you all think? Adding height to the tub walls is not an option, as this tub arrangement makes the room "spiffy".
Thanks for all of your help,
Paul
Paul
