Results 1 to 2 of 2
Thread: replacing flapper on TOTO toilet
    DIY Junior Member
    Feb 2010
    boston
    Default replacing flapper on TOTO toilet
    I have a TOTO Dartmouth CST754SF. The flapper eyelet that connects to the chain broke. I have two questions: What will be the right flapper replacement? Also, the vertical tube that has the two rods to which the flapper connects sits very close to the back wall of the tank, so that there is no space to remove the old flapper hinge or install the new one. Suggestions?
    thanks for any help you can provide.
    It's the red g-max flapper.
    Korky makes replacements for Toto,
    Lowes Hardware carries them.
    It the pin is too close, you can pull the tank, loosen the large nut on the bottom, and swivel the flush valve away from the side of the tank.
