PhilfromFlorida
My neighbor's submersible pump isn't working right. I have the same system and I live next door. The pressure switch contacts were sticking so he bought a new switch at home depot and replaced it, making sure the wires were returned to the same screws. The pump runs and there is good water pressure inside and out, but the switch (30/50) will not cycle and the pump remains on. We put the old switch back on and it still will not cycle. It was cycling before he changed it. I check the air in the tank and the pressure was about 10 psi. the pressure hadn't been checked over the years. So, we added air to the tank to bring it up to 28 psi according to the instructions for a 30/50 switch. Still, the switch will not cycle with the new or old switch. And we noticed that the tank is not filling with water. My neighbor can't remember if the pump had been cycling rapidly lately or if water had been in the tank or not. So, the question is why won't the pump cycle on and off (stays on unless the breaker switch is turned on and off) and why isn't the tank filling with water? Thank you very much for any info you can give. Phil.
