I live in a relatively new home and checked my water pressure today on both hose bibs and it sits around 56 to 57psi with all faucets off. Then I ran a hot water faucet inside for 10 minutes (then shut it off) which kicked on the water heater. The pressure spiked around 73 to 74 psi while the heater was running. It dropped back to around 60 psi within 15 minutes, and then drops a tad lower after 45 minutes or so. Is this OK or should I lower the pressure down some with the PRV? I don't want to have premature leaks due to high water pressure. The entire house is PEX with the except of the copper tubing that comes out the walls where the shutoff valves are located. Just want to make sure I have an acceptable pressure rating especially with it going up to near 75 when the water heater is working.
