Results 1 to 3 of 3
Thread: ASME approved heat exchangers
    Web Development | HVAC patsfan78's Avatar
    Jun 2009
    Maine
    Default ASME approved heat exchangers
    What makes a giannoni or any other heat exchanger ASME approved. For example the heat exchangers in a LAARS Mascot or a Baxi. Should the H stamp always be on an ASME heat exchanger or is the H stamp an additional approval on somthing.
    I am not refering to a brazed plate heat exchanger. It just kinda funny Gianonni says one thing but the ASME heat exchangers I have seen dont seem to match up to the giannoni ASME exchanger examples.
    Is it the welding of the manifold or the welding during the construction of the entire heat exchanger??
    The classic heat exchanger is what I have seen on most wall hung boilers but it seems here it does not have an H stamp.
    http://www.giannoni.fr/products.php
    Thoughts??
    DIY Senior Member zl700's Avatar
    Aug 2009
    Texas
    The ASME H stamp on a heat exchanger means that the weight, thickness, material, stress capability, welds and means of assembly meet section Section IV of the ASME Boiler and Pressure Vesel Code. These are rules for the construction of heating boilers.
    In addition, all ASME "H" Stamp heat exchangers are inspected one by one by a certified ASME technician before the component is used to construct the boiler.
    Depending on type, size and weight this whole process with inspection adds $175-$250 to the cost of that exchanger to bear the right to have the "H stamp".
    Jun 2009
    Maine
    The question remains as to why a Baxi says it is ASME and bears the H symbol on its packaging yet no H stamp on the exchanger itself.
    Mike
    HiTech Heat, LLC
    www.HiTechHeat.com
