Before spending the money to install a PumpSaver is there any way to tell if your well is running down so low your pump is running in a dry-well cycle?
Would a water pressure gauge having a memory needle that records the highest psi reached be of any help to determine your submersible pump has sucked the well dry and continued to run or experiences dry-well? If so where is the best place to attach the gauge in the system.
Roughly how many dry-well pump cycles can a 5HP; 25GPM Jacuzzi submersible pump; 230V single phase; take or withstand before it would start to fail?
Thank You For Your Input!!
