Sorry AKpsdvan, I don't understand what this is about; "This has turned in to a poll cat marking contest...." If I guess, I come up with you being upset because you think I'm pickin' nits... I wasn't but at times I think others are.
Originally Posted by
Skip Wolverton
A 4 cu ft unit on 20 GPG water. You would have to use 500 gallon per day in order to regen every 8 days. IMO, a 4 cu ft is
way over sized.
That's because you don't understand how to size or set up a softener by adjusting the K of capacity you need by the salt dose in lbs based on the volume and type of resin you are using so you mistakenly think 120 or128K.
