Ched
I've searched online for the past 2 nights and still can't quite figure this out for myself so I'm hoping someone here can.
In my basement I have a laundry sink and washing machine connected with 1 1/2" pipe into a 3" drain. The washing machine ties into the sink's drain before the P-trap. I tried my best to capture it in the attached drawing - the washer sits next to the laundry tub and the dryer between the washer and the 3" drain pipe.
Every time the washing machine empties, it backs up into the sink. I'm not sure why this is happening but its been this way since I moved in. I snaked the drain from the laundry tub to the 3" pipe and it didn't fix it so I was left thinking it was something to do with the way it was plumbed.
I just bought a new laundry tub because the old one is filthy from paint, crud, and 28 years of wear & tear. Instead of just simply replacing the tub and living with the back-up problem I thought I might as well fix the whole thing properly so I don't get the washing machine water backing up into the sink anymore.
I thought that installing a new 2" drain for the washer and tying it into the 3" drain might solve the problem but I wasn't sure how that should be vented.
What's the proper way for this to be hooked up? Is it correct already? Any help/advice would be appreciated.
