GoshenPlumber
I have a pressure regulator (Watts 25AUB-Z3) in a pit downstream of the water meter at the edge of my property. See the diagram below. The regulator is set so that the incoming pressure in the house as measured on a gauge in my basement is approximately 45 PSI. I recently noticed that over night, the pressure increases to about 70 PSI by the morning. I also notice that in the morning, if I open the cold water tap, the excess pressure is relieved in about 10-15 seconds, and the system returns to the set pressure of approximately 45 PSI.
What causes this drift upward? How can I tell if this drift is caused by a failing regulator, dirt/debris on the regulator seat, or thermal expansion from the hot water tank? If the problem is thermal expansion, does this mean that either the check valve or expansion tank needs to be replaced? If so, how do I determine which one?
I would appreciate recommendations on what I should do to solve this problem.
==> Water ==> Pressure == 120' to ==> Gage in ==> Check ==> Expansion ==> Cold water lines
meter regulator house basement valve tank ==> Hot water tank ==> Hot water
lines
lines
