Results 1 to 9 of 9
Thread: In Wall Horizontal Pipe Runs
Hybrid View
    DIY Junior Member
    Jan 2010
    OFallon, MO
    Default In Wall Horizontal Pipe Runs
    I am in the process of finishing my basement and have a strange question. When you are running pipe horizontally within the walls (notched or through holes) which pipe runs above the other? Is the hot pipe on the top or the bottom?
    Also another (similar question)... in this basement I have an existing stack which was installed during construction for the half bathroom. The builder placed a saniary tee at the height for a sink drain and then capped it off. This stack sits between the bathroom and where a wet bar will be. I want to use that stack (2" stack w/ 1 1/2" stub) to drain both of the sinks. Can I run the pipes between the two sinks with another tee in the middle and connect the combined waste into the existing san tee? The sinks would both be in 1 1/2" PVC.
    Thanks for the help!
    Jason
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    There isn't any code that says which water pipe should be on top or the bottom. Good plumbing practice is to run both pipes as to not cross them. In other words, where ever possible, do not cross one pipe in front of the other.
    Your second question is =no
    Each fixture should be individually vented and separately trapped
    Most plumbers run hot high and cold low.
    It's not code, but it's common.
    DIY Junior Member
    Jan 2010
    OFallon, MO
    Thank you all for your help... Is there a "standard" for the height of the pipes in the wall? (The actual runs, not the connections for the fixtures which do have a typical height)
    Jason
    Jun 2009
    Canada
    Quote Originally Posted by jasonal119 View Post
    Jason
    Shortest route possible.
    You're over thinking this.
    Previous member
    Jul 2009
    North of the Mason dixon Line
    If you go with pex you can just throw it any witch way and no one will care
    DIY Member Lightwave's Avatar
    Aug 2007
    Vancouver, BC
    Don't place them 14" from the floor unless you're sure you're never going to put an electrical outlet in the wall.
    Don't place them 48" from the floor unless you're sure you're never going to put a light switch in the wall.
    Keep hot and cold pipes far enough apart that they can be insulated separately.
    Insulate all supply pipes that run above wiring or electrical boxes.
    Avoid running pipes in outside walls above frost depth unless you have no other option.
    IN the "old days" when piping was exposed, we ran the cold on top so that if someone leaned on them they would not get burned by the hot water pipe. WHat you want to do is possible, but the real factor is HOW you do it. That would determine whether it was correct or not.
