Thread: water softener is not pumping water into brine tank.
    DIY Junior Member crabby's Avatar
    Jan 2010
    nova scotia
    Default water softener is not pumping water into brine tank.
    water softener has stopped pumping water into brine tank. all brine has been removed from the brine tank by the softener unit. there is only dry salt in the brine tank now. what happened Terry?
    thanks
    wi
    If you have a float in the salt tank, make sure it is not stuck in the up position; that shuts off water flow into the tank.
    Or you could have a blocked screen filter inside either end of the brine line if you have a screen. Or the screen by the injector or the injector or its throat could be blocked. Or the brine line flow control button could be blocked etc. etc..
    What brand of softener do you have, or what brand of control valve do you have? If you don't know describe the face in detail as if I was blind and you wanted me to know what it looked like. Or, post a picture.
    Some unit are set to "fill first" so the brine level will be about 1' from the bottom.
    Dec 2009
    Alaska
    Brand of unit?
    Kind of unit?
