Results 1 to 3 of 3
Thread: pex and steam heat
    DIY Junior Member arturofitz's Avatar
    Jan 2010
    NYC
    Default pex and steam heat
    I have a steam boiler I want to put another zone in my basement .I put a ciculating pump on The pex that I bought has an oxygen barrier and is for base board heat HOWEVER I just noticed that it is rated for 180F and I am sure that my steam boiler puts the water hotter than that IS there a PEX rated for steam???
    Aug 2009
    South*East
    Are you using a heat exchanger? If not then all your piping must be well below the water level in the boiler.
    John
    Previous member
    Jul 2009
    North of the Mason dixon Line
    Short answer is no, you can't use pex.
