The easiest way is if the pipe is long enough to just cut it behind the ring.
There is a ferrule puller tool which easily pulls off the ring.
If you are careful, you can slice the ring diagonally, using a hacksaw blade wrapped in duct tape and held in your hand. Orient the blade to cut on the pull stroke.
