First thing I'd try to to ensure all of the joints in the ducts are sealed so they don't leak. Then, if you don't have any dampers in the system, you might install them t oforce more air where you want by partially blocking off those areas that get plenty or too much. A new, higher efficiency furnace won't resolve your issue if you don't make any changes to the ductwork. Tighten it up, then see what happens.
