Scott99
- Messages
- 33
- Reaction score
- 0
- Points
- 0
Greetings,
I'm replacing my PVC pipe that feeds my irrigation system. It's the PVC piece that comes from the anti-syphon valve and goes into the ground then elbows out.
I want to replace just the exposed piece with copper. No problems with getting the copper into the ground with a copper elbow and short stub with a female fitting on the end.
my plan was to use connect to the copper with a threaded male PVC end that has a short piece of PVC tubbing attached. then use some type of coupler to attach that end to the pipe feeding the irrigation system.
Are slip couplers or compression couplers reliable for this? It will be underground so I won't see any tiny leaks. if so which one is better?
