Thread: Heating oil tanks
    In the Trades mike32's Avatar
    Sep 2005
    Pittsburgh PA
    Default Heating oil tanks
    I purchased my home last year, and it has oil heat, there are two 275 gallon tanks, they are indoor tanks located directly next to each other. The problem i have is that last autumn i called to have them filled, only to find out they are connected to each other the wrong way. The fill pipe goes into both tanks and there is a vent on each tank. The vents are connected together and exit thru the foundation to atmosphere. When the fuel guy was here he stopped fueling and said the tanks were full, when actually, only one tank was full and it was the tank on the end of the fill pipe, and fuel was coming up and out of the furthest tanks vent, so the whistling/rumble sound stopped, in essence that indicates full tanks.Which leads me to my question. To remedy this should i remove the vent from the furthest tank and connect a solid pipe from the vent hole to the other tank? I realise both tanks need sufficient venting for flow of fuel and pressure build up.
    I checked for clogged or backed up piping, all piping is in excellent working order with the exception of the issue mentioned above.
    Apr 2005
    Yes. I would do as you mentioned to correct the problem.
    Sep 2005
    Pittsburgh PA
    Thanks for the reply
