IF 3" is the "proper size", not just the minimum size, then there is usually no advantage to using a larger size, but this is not an iron clad rule for smaller drain lines. WHY can't you fit a 4" pipe into a 2x6 wall? We do it all the time when we have the need for a 4" pipe.
