Results 1 to 14 of 14
Thread: Vacuum relief on cold water feed?
    DIY Senior Member vtxdude's Avatar
    Nov 2009
    NH
    Default Vacuum relief on cold water feed?
    I can't remember what it is called but usually on the cold water feed to the water heater there is an extra brass piece that I think the plumber said is a vacuum relief something or other.
    When he put in the new water heater he said that they were no longer required. It was attached right to the cold water feed on my water heater but now I have just the straight copper pipe.
    Is this needed? Reason asking is that pipes seem a lot nosier now when a call for water is initiated such as washing machine or if WH is refilling etc
    Dec 2005
    SW Florida
    Was your old model a bottom fed unit?
    Matt
    Enjoying life in SW Florida
    I don't know what the NH code is, but Nashua requires them on installation along with a tempering valve. Was a permit pulled and an inspection done? That would tell you for sure what was required. The vacuum breaker should(at least in my limited experience) have no affect on the sound of water running.
    Nov 2009
    NH
    Im talking about the brass fitting here off the cold water feed
    Plumber said no longer required
    What is it's purpose?
    Here is pic of new piping
    Tempering valve? You mean the T/P?
    Dec 2005
    SW Florida
    Down here it's only required for a bottom fed unit.
    Tempering valve is not a T&P.
    Matt
    Aug 2009
    Midwest
    For process vessels typically a 150 psig rating was good enough to rate a vessel for full vacuum as well. Since the water heater relief is set to that I really doubt vacuum protection is necessary. For my process equipment design group it was customary to spec anything requiring moderate pressure (say 75 psig+) at 150 psig and full vacuum as there was little to be gained savings wise from lower pressure rating and it made the overall design simpler and more robust. Vacuum relief devices posed a lot of problem when boiling ether, gasoline, and other light hydrocarbons.
    Vacuum will collapse a vessel more easily than pressure will blow it out. Regardless, if it is required by code in your area, you put one in if you want to pass.
    Nov 2008
    Chicago, IL
    Is your water heater installed in the basement? If not is there any plumbing fixtures lower than the water heater?
    Here they are required if the water heater is installed above any other plumbing fixture. This way it will prevent vessel from collapsing if the water where turned off at the meter and someone opened a fixture.
    Nov 2009
    NH
    It is in the basement.....the plumber said used to be a requirement but is no longer..maybe different requirements for Nashua vs Merrimack? Who should be able to confirm? Water Dept?
    So the absence of this should cause any difference in pressure or cause more of a clicking noise at the meter (knocking noise at where meter is tied into the j-horn when water is being drawn) Seems like faster meter spins for washing machine, toilet, shower the louder the knocking noise..it is only at the pipe attached to meter...can post pic later to clarify
    Nov 2008
    Chicago, IL
    Best person to contact to confirm if it is not required is the plumbing inspector from the building department of your city or town. Not having a vacuum relief valve will not affect how your meter is working or water pressure. It is a safety device to prevent a vacuum from collapsing the tank if the city shut of the main and someone opened a faucet below the heater.
    Quote Originally Posted by vtxdude View Post
    Aug 2009
    Midwest
    Yes, and that is why it takes about 10x the internal pressure rating (150 psig) to achieve the 14.7 psi external pressure (vacuum) rating.
    I don't think I've ever lived anywhere that required vacuum breakers on the hot water tanks. I wonder if that is because the municipalities I've lived in three widely separated states typically have not had residential boilers? From what I've gathered here the design pressures of these residential boiler shells appear to be lower and therefore probably at risk of vacuum collapse. The boilers I've worked with have been industrial ones producing 600 - 1600 psig steam.
    Default vacuum valve
    Even where they are "required" the actual installation of the heater would determine whether it is necessary. Usually they are more of a nuisance that anything because they can develop leakage through the port.
    HVAC Jah0983's Avatar
    Feb 2011
    Manassas VA
    Hi all came across this thread and have been trying to get a ? answered. Is this an older style vacuum relief valve? Is it replaced by the watts N36-M1? Thanks in advance for any response!
    We would "guess" that it's a vacuum relief valve.
    Some places like to see them on electric tanks to prevent the elements from running dry and burning out.
