Cordoba
Hello everyone,
Hoping someone may have some ideas on this.
I had a new well drilled in Feb. 2009 because the old well was pumping large amounts of silt. Looked like wet muddy sand from the beach. The new well is 175 feet deep. The well seemed to be OK until about Aug 09 when we started to see small amounts of silt coming through. I had a local guy who services wells come in to inspect and he changed the whole house water filter (filter is approx 10" wide). After about 30 days that filter clogged again so he came back and removed the entire filter system and installed what he called a cyclone filter which has a smaller filter cartridge but it can be removed, washed and re-installed. The casing of the old filter system was very difficult to remove due to sand getting in which was the reason for the new system. Now the problem seems to be that the filter gets plugged after 1 or 2 days and all water in the house stops until the filter is removed and cleaned.
After speaking with the gentleman that installed the filter he told me that I should be going back to my well driller and pushing him to fix the well. His thoughts are that it possibly has something to do with the screen and it's an error on the drillers part because the well should be pumping sand free water. He also mentioned that it requires getting the rig back in there?? I called the driller he says he's not sure what the problem could be. He wants to see a water sample first. I called another well driller as well and his opinion was to pump the well continuous for 12 hours, let it stand for 1 hour then pump it again for another 12 hours and repeat. My filter guy doesn't think that will work from his experience with servicing wells.
Sorry for the long post. Looking for advice.
Thanks. Mark.
Thanks. Mark.
