No, that ain't normal and indicates a problem in the valve head.
I have a Kenmore Deluxe Demand Water Softener that is approximately 12 years old. Lately, I've noticed that while the master bathtub is being filled, the water softener discharges water to the overflow drain. I don't know if this has just started occurring or perhaps I just never noticed before... at any rate, can anyone tell me if this normal or is it indicative of a problem that needs to be corrected? Thanks!
Or a crack in the media tank.
Seen one do that about a year ago.
Thanks guys - I was afraid you'd say that! I guess that gives me another project![]()
Let us and the others know what you find out as to where the leak is at.
The drain seal inside the valve is springed assisted. I've seen the stick and run to the drain. If it is weak, maybe the flow to the tub allows the drain seal to open. Just a thought.
