Results 1 to 7 of 7
Thread: Laundry water auto shutoff
    Default Laundry water auto shutoff
    Is anyone familiar with a device that attaches to the hot and cold water supplies for the washing machine. If water is detected it shuts the water off.
    I am looking a brand that works well.
    Peter D
    Plumber jimbo's Avatar
    There are many devices available. They use some type of sensor which sits on the floor and connects to solenoid valves. Google on water-shut off and similar terms. You will find them.
    Jul 2005
    Marin Co. Ca.
    Default i use a watts valve
    buy the one that has the water sensor for under the wash. machine
    I have found a couple now I need to evaluate. Anyone have an idea if the Anti-Water hammering devices the plumber installed on the hot and cold outlets should be placed before or after these auto shutoff valves?
    It anybody really using these autoshut off devices?
    Peter
    DIY Member Vitaliy's Avatar
    Sep 2005
    Massachusetts
    Why to bother with semi solution?
    Just install “watercop” http://www.watercop.com/ next to your main
    shutoff valve and your entire house will be protected. Yes, “watercop”
    is more expensive but it gives you a lot more of protection.
    Sure, I have one installed.
    - Vitaliy
    Quote Originally Posted by Vitaliy
    - Vitaliy
    Of if you're on a well, just run an extension cord from the outlet to the floor so the GFCI will trip if it floods. (don't really do this!)
    Jul 2005
    Marin Co. Ca.
    Thumbs up thank,s vitality
    never heard of water cop
    always learn something new on this great site
