There are several tools to remove that drain fitting, but you do not have them and I do not know where you could find them in your area. If you can find a piece of flat steel the right thickness and width, you can insert that into the slots and use that to unscrew it. You could also cut the strainer out using a hacksaw blade. This would not have to be as precise as usual since you are discarding the tub and do not have to worry about damaging it.
