Thread: bathtub drain question
    DIY Junior Member
    Jan 2010
    ATL
    Default bathtub drain question
    I have a tub with a built in drain shoe. The lever broke right behind the mounting plate. then as I was taking it out of the tub I lost he spring down the drain! Is this part something I should be able to find at Home Depot, or Lowes, or will I have to go to a Plumbing supply store to get it?
    I'm hoping it's not something that is part of the original bathtub, and is still available.
    I attached a picture of the part in question.
    Aug 2009
    South*East
    You can buy just the face plate and attach the existing plunger or get the complete assemble. Big box stores may have them either way.
    John
    Default drain
    The spring should not cause a problem, but if you can find a small magnet on a string and drop it down the pipe it will be retrieved. The overflow plate is a generic item, just be sure to use a brass cotter key to attach the clevis to it. If the new one comes with a steel cotter pin, reuse the brass one from your old drain.
