Results 1 to 2 of 2
Thread: repairing a section of cpcv pipe
    DIY Junior Member
    Jan 2010
    Colorado
    Default repairing a section of cpcv pipe
    After cutting out a section of FlowGuard cpcv pipe with a leaking elbo attached to a T, how do I re-insert the new section into the new sleeves on the ends of the two sections from which it was cut? It doesn't seem like the pipe is flexable enough to bend and angle it into the sleeve. Do I apply the cement on both ends, try to fit the pipe into the sleeves and position it all at the same time?
    Default pipe
    You cannot repair ANY pipe without being able to move the two sections apart far enough to insert the repair, either by flexing them or spreading them. If you cannot move the two ends you either need to use a union or multiple fittings to create a means of fitting things together. DO NOT try to insert the pipe into a fitting, and then pull the fitting back onto the other side.
