Thread: luke warm water
    DIY Junior Member
    Jan 2010
    Utah
    Default luke warm water
    I installed a Pegasus 898 056L shower set. I cannot get hot water. The cold works fine and when I rotate the handle to the hot side it is only luke warm.
    Assuming the hot supply is really hot, all new shower controls have a high limit mechancal adjustment. On some, it is a screw, on others it is a lever. You'll need the instructions to figure it out. Normally, you have to take the trim off to reach it. Because summer incoming water is normally warmer, if you adjust it in the summer, it will be cold in the winter, and vice-versa. That's one reason why I prefer a themostatically controlled valve. Set the desired temp, and it works the same winter/summer, end of tank, beginning of tank.
    In the Trades AAnderson's Avatar
    Oct 2009
    Aptos, CA
    Quote Originally Posted by dennislewis View Post
    first is the water in your lav sink hotter than in the shower or the same? I assume the lav is hotter because the installing plumber had not adjusted the disc on the valve after setting trim. this typically sets behind the trim and is more or less intuitive. It prevents you from turning a handle beyond a fixed point. It can be lifted off the valve and rotated to the left to give you higher temps.
