Please help! Sediment clogging pipes
mward77095
Cypress
Hello, thank you in advance for your assistance with this...
I live in a 5600 square foot house that we built about 1.5 years ago. We are on a water well. We had a problem with the well and ended up getting a lot of sediment, rocks, sand, etc. brought in with the main water supply. The problem with the well has been fixed and I have clean water coming into the house now. However, I can't seem to get all of the sediment out of the pipes in the house. All of my water fixtures and appliances are getting clogged at the screens / filters. I have cleaned them out several times and have tried flushing the plumbing lines by running the water out of several fixtures for several hours but can't seem to get rid of it. The master shower is the worst... probably because it gets used the most. I have to clean the sediment out of the fixtures at least once a week and have to clean out the valves about once a month. By the way, I am using a tankless water heater.
Please help... is there a way to back wash the system or apply additional pressure for flushing, or something???
Mark
Doherty Plumbing
Journeyman & Gas Fitter
Penticton, BC
www.facebook.com
Mark
This is going to be VERY time consuming but this is what I would do:
1. Install a filter/screen on the incoming water to filter out the bigger stuff. Put isolation valves around it so you can easily clean and maintain it.
2. Install hose bibb style connections on to every water supply line you can get at and blow them out one at a time a few time. I would probably start with the bottom floor then work my way up. Do that a couple of times.
Sediment in the lines is a pain in the ass....
NHmaster
S. Maine
Start by draining the expansion tank off. close the house feed, put a hose on the tank and let it rip. Do the same thing at the water heater.
mward77095
Cypress
What do you mean "blow them out one at a time? Do you mean let the water run at full blast out of one hose bib at a time?
