lbk
I have a serious water problem. My crock is continiously filling up and it doesn't stop until July/August. When it rains - major water. Spring thaw - major water. I have one pedestal pump that runs all the time. I have another pedestal pump in the crock with the float set a bit higher because I fear that the switch will go out or the electric motor will burn up. The pump(s) keep up ok, but they never stop because there is always water coming in.
A batttery backup isn't feasible because there is not room in the crock for another pump. Either way, a battery would not last long because it runs continious.
Once - only once thank god - both pumps were working and barely kept the water from oberflowing.
I have to find some way to reduce the flow of water. There are no drainage problems - surface water and the pumped water flows far away from the house. I think there is a underground river next to the house. Does that make sense?
I flooded on Christmas day this year and it ruined my whole basement and my holiday - I'm in tears - literally - over this. Everything was just about ruined.
Can you people discuss this with me and help me find a solution or some ideas anyway. Thanks.
My name is Bob.
My name is Bob.
