Page 8 of 18 FirstFirst 1234567891011121314151617 ... LastLast
Results 106 to 120 of 268
Thread: Toto Aquia dual flush toilet product review, comments and posts.
  1. #106
    Quote Originally Posted by Acerone View Post
    I'm sorry but which toilet seat do you order with your Aquia II?
    Toto is going to recommend the (more expensive) Oval SoftClose seat, SS204.
    However, any elongated seat should work for the Aquia series. I would recommend the regular SoftClose seat from Toto. SS114 as shown in the picture Terry posted.
    Rob
    Sales
  2. #107
    Thanks for the tip... I perfect the look of the SS114...
    SS204
    SS114
  3. #108
    DIY Junior Member machabs9's Avatar
    Jul 2009
    Canada
    Default My Aquia Leaks
    I had an Toto Aquia II installed 'professionally' a few weeks ago. It seems to work fine normally but has leaked twice on me - from the bottom of the toilet, it doesn't overflow through the bowl.
    The contractors original blamed it by rough iron pipes. A blockage it not out of the question, but should it be leaking out of the bottom??
    Does this sound like a case of a bad or improper seal?
    Are there any 'tricky' steps in installing an Aquia II that are different from a normal toilet install that could be missed??
    Thanks.
  4. #109
    The best instructions for the Aquia are here
    http://www.terrylove.com/forums/showthread.php?t=12606
    Any toilet that leaks from the floor seal, you have to suspect a main line backup.
  5. #110
    Jul 2009
    Canada
    Default Please elaborate
    Thanks for the response Terry.
    With a good seal, wouldn't even a main line back-up just overflow the bowl and not leak under the toilet onto the floor?
    The leaking occurred after several flushes within a 30 minute period.
    Could this be a slow draining main line?
    Might I have two problems... the seal and main line back-up/slow drain?
  6. #111
    These adapters are installed with a seal at the flange.
    We normally use wax.
    If you have a main line backup, don't expect wax to hold very much head pressure.
    If it is a backup, the toilet flange is normally the lowest point in the home, followed by tubs and showers.
    It's easy enough to pop the bowl off and check the flange seal though.
  7. #112
    Jul 2009
    Canada
    Default Resolution
    It turns out there were two problem at play here.
    1) There was a partial main line blockage.
    2) Also the wax seal used was not sufficient. I was told this model needs an extra tall wax seal. My contractors originally used a regular wax, for the fix they used a regular wax seal on top of a wax seal with neoprene(?) base. This double tall wax seal seem to do the trick, but only the next main line back-up will tell me sure. Does this sound right that an extra tall was seal is need for the Aquia II?
    Happy Flushin'
  8. #113
    Anytime the flange is lower then the finished floor, you need more wax.
    Unless the flange is installed "over" the floor, it takes more then a single wax ring.
    For any bowl or toilet.
    But then any plumber knows that.
    A handyman might not know that.
  9. #114
    DIY Junior Member DamonC's Avatar
    Sep 2009
    Central Coast, CA
    I have a bit of a side question, but I thought it would be good to keep questions regarding the Toto Aquia together.
    Does the Aquia (not II or III versions) fit a 10" rough-in? It seems like it is the only version that uses the unifit adapter(?), but i just wanted to check that this was a viable option for my home.
    Thanks for any input,
    -Damon
  10. #115
    There is no 10" option for the Aquia.
    Rough-in must be at least 11-1/2"
  11. #116
    Sep 2009
    Central Coast, CA
    *sigh* Oh well.. I was really getting set on an Aquia.
    I've heard that Toto is supposed to be coming out with a 10" Aquia very soon, but i can't say how reliable that source it (a local boutique home appliance store).
    Is Caroma my only option for a 10" rough-in dual flush toilet? I may just go with a 1.28gal toilet instead, like the Guinevere or Soiree.
    Thank you for the definitive response.
    -Damon
  12. #117
    DIY Junior Member pp's Avatar
    Sep 2009
    San Juan Capistrano
    Default SanaGloss or not?
    Hi Terry,
    I just purchased a TOTO CST464MF-01.
    Will this have the SanaGloss finish or is there a different model number to obtain that. I'm hoping TOTO is using that finish now on all models, but not sure.
  13. #118
    Apr 2007
    Ontario, Canada
    Quote Originally Posted by DamonC View Post
    -Damon
    There is a 10" coming soon CST416MF.10 Universal Height as well as 10".
    The price book says "Available 3Q09" 3rd quarter of 2009, but with Toto i would say to be safe 1st quarter of 2010.
  14. #119
    Apr 2007
    Ontario, Canada
    Quote Originally Posted by pp View Post
    Hi Terry,
    That model does not come with Sanagloss and there is no option for any of the Aquia's with Sanagloss.
  15. #120
    Sep 2009
    San Juan Capistrano
    Default Sangloss
    Do you know if there is a reason not to offer the SanGloss finish? Reports on it's characteristics are so good.
