Page 17 of 18 FirstFirst ... 789101112131415161718 LastLast
Results 241 to 255 of 268
Thread: Toto Aquia dual flush toilet product review, comments and posts.
  1. #241
    Here is the one-piece version of the Aquia.
    Now you pull the bowl from the box and stick it down on the flange adapter and over the mounting blocks.
    No need to even install the tank, it's all molded in.
    MS654204MF, comes with a SS204 Softclose seat.
  2. #242
    DIY Junior Member abarclay's Avatar
    Dec 2011
    Brentwood, California
    Just thought I would throw my two cents in here. I installed this toilet and had a leak on the left tank bolt. I tried removing the tank and re-installing several times. I tried sanding the inside of the toilet around the hole and re-installing. I went so far as to alternate tightening the tank bolts a quarter turn each until they were tight. I tried over-tightening to the point where I was worried the tank would crack (thank goodness it didn't). Each time, it leaked. Finally, I used a coat of RTV silicone on the rubber washer that seals inside the tank. This fixed the leak. I'm not sure what else I could have done, but now the toilet is working great.
  3. #243
    DIY Junior Member brook0's Avatar
    Jan 2012
    New York
    I noticed the Aquia one piece only has a 1-3/4 inch trap compared to the 2-1/8 trap on the Aquia CST416M. Do you think that this could affect the performance in a negative way. Does anyone have any real world experience with the one piece Aquia?
  4. #244
    Comments by readers Reader Review's Avatar
    Jan 2006
    Default Cst412mf.10
    Toilet and everything looks great, thanks again!!
    Robin V
    Seattle WA
    TOTO Aquia with 10" Rough, CST412MF.01
  5. #245
    DIY Junior Member Seattle2k's Avatar
    Nov 2012
    Seattle
    I have one too. Recently, it seems it's not flushing as much water. I know I can adjust that though. Otherwise, the toilet works and looks great.
  6. #246
    DIY Junior Member lecvar's Avatar
    Sep 2013
    CA
    We purchased an Aquia MS654114MF and are in the last day of a bathroom remodel only to discover that we have 11", not 12" for the rough in. Does anyone have any experience with using this model with an offset flange?
    Thanks for an amazing site. I've learned more in the 17 pages than 47 years!
  7. #247
    You can set these at 11.5"
    You may be able to fudge the adapter the rest of the 1/2" by setting it offcenter to the flange.
    The outlet is 2", and you are dropping it into a 3" pipe. There is some room to play with there.
    We sometimes use a flange repair ring to hold the closet bolts at the "new" center.
    Do not use an offset flange.
  8. #248
    Sep 2013
    CA
    Thank you Terry.
  9. #249
    DIY Junior Member kohinahi's Avatar
    Oct 2013
    Virginia
    Hi!
    I need some help with a powder room project and would greatly appreciate if someone with an installed Aquia II 12" rough-in toilet can provide me with some measurements. The issue is that my chrome threaded pipe nipple is 3" from the center line, protrudes 4" (including the valve) from the wall and is 5" off the floor. I was planning to install the Aquia II (CST412MF or CST416M) toilet and need to know if the back of the toilet can accommodate my current nipple placement. It would be very helpful if you can let me know the rear clearances.
    If the toiler rear cannot accommodate the nipple, can someone let me know how easy/difficult it is to swap out the nipple with a new shorter one? I am only experienced with copper pipes.
    Thank you!!
    Aquia II on a 12" rough
  10. #250
    Apr 2012
    New York, NY
    If it doesn't fit because of the protrusion, you can install one of these Dahl Skirted Toilet kits, which is basically an integrated 90 with a quarter-turn ball valve attached.
    http://www.dahlvalve.com/products/mi...oilet-kits.php
  11. #251
    Oct 2013
    Virginia
    Terry/wjcandee, Thank you.
    Quote Originally Posted by kohinahi View Post
    Hi!
    Thank you!!
  12. #252
    DIY Junior Member bronsonb's Avatar
    Dec 2004
    Smyrna, GA
    Hi!
    Thank you!!
    Hi there. Not a plumber, but I happen to have the same toilet installed. I measured behind mine, and in that "cut out" area in the back (just above that "foot" at the base) it's about 6.75" from the wall to the back of the toilet. Sounds like the nipple would fit, but I don't know if you'd have room after mounting a shut off valve on it. I think you'd clear the back of the toilet that is closest to the wall, and the pipe is high enough to put it inside that "cut out" area (if all of this is making sense).
    I'd just be concerned about having enough space for the shut off valve. Hope this helps at least a little bit.
  13. #253
    Oct 2013
    Virginia
    Quote Originally Posted by bronsonb View Post
    Thank you! That does help.
  14. #254
    Oct 2013
    Virginia
    One additional question. Would anyone know if are these two TOTO toilets -- CST416M (Aquia II) and CST412MF (Aquia) are identical except for the height? I looked at the CAD drawings and specs (the supply line area looks different) and could not determine if they both had the new Aquia II type cutout? I saw an Aquia toilet where the skirt extends towards the wall -- covering the cutout area in the Aquia II. TOTO representatives claim that the only difference in the two above models is their height - 16 3/8 for the Aquia II and 17 1/8 for the Aquia.
    Thank you in advance!
  15. #255
    Original CST414M installed with the old style SS114 Seat. This installation must be about ten years old now.
    While I was installing a new tub downstairs, the homeowner commented how much she loved this Aquia. Thinking she may want to take it with her if she moves.
