Page 17 of 17 FirstFirst ... 7891011121314151617
Results 241 to 245 of 245
Thread: Toto Aquia dual flush toilet product review, comments and posts.
  1. #241
    Here is the one-piece version of the Aquia.
    Now you pull the bowl from the box and stick it down on the flange adapter and over the mounting blocks.
    No need to even install the tank, it's all molded in.
    MS654204MF, comes with a SS204 Softclose seat.
  2. #242
    DIY Junior Member abarclay's Avatar
    Dec 2011
    Brentwood, California
    Just thought I would throw my two cents in here. I installed this toilet and had a leak on the left tank bolt. I tried removing the tank and re-installing several times. I tried sanding the inside of the toilet around the hole and re-installing. I went so far as to alternate tightening the tank bolts a quarter turn each until they were tight. I tried over-tightening to the point where I was worried the tank would crack (thank goodness it didn't). Each time, it leaked. Finally, I used a coat of RTV silicone on the rubber washer that seals inside the tank. This fixed the leak. I'm not sure what else I could have done, but now the toilet is working great.
  3. #243
    DIY Junior Member brook0's Avatar
    Jan 2012
    New York
    I noticed the Aquia one piece only has a 1-3/4 inch trap compared to the 2-1/8 trap on the Aquia CST416M. Do you think that this could affect the performance in a negative way. Does anyone have any real world experience with the one piece Aquia?
  4. #244
    Comments by readers Reader Review's Avatar
    Jan 2006
    Default Cst412mf.10
    Toilet and everything looks great, thanks again!!
    Robin V
    Seattle WA
    TOTO Aquia with 10" Rough, CST412MF.01
  5. #245
    DIY Junior Member Seattle2k's Avatar
    Nov 2012
    Seattle
    I have one too. Recently, it seems it's not flushing as much water. I know I can adjust that though. Otherwise, the toilet works and looks great.
