Page 13 of 18 FirstFirst ... 3456789101112131415161718 LastLast
Results 181 to 195 of 268
Thread: Toto Aquia dual flush toilet product review, comments and posts.
  1. #181
    Comments by readers Reader Review's Avatar
    Jan 2006
    Default CST416M with SS114 Softclose seat
    We really like the toilet.
    Jamie did the installatio, and replaced the cold water shutoff at the wall.
    Nancy F.
    Bellevue WA
  2. #182
    General Contractor Carpenter toolaholic's Avatar
    Jul 2005
    Marin Co. Ca.
    wow 15" clearance each side ?
  3. #183
    DIY Junior Member Jeff K's Avatar
    Jul 2010
    Bethesda, MD
    Default Warranty
    Who knew that there were so many variations on toilets?
    We are doing some bathroom remodeling and are interested in installing dual flush toilets to save water. I noticed that the Aquia has a 1-year limited warranty while other Toto toilets have a 5-year warranty. Are there durability problems with the Aquia?
    Thanks for all the great information.
    Jeff
  4. #184
    I've been selling the Aquia for years now. It has been one the most trouble free toilets I have ever sold, even better then the Drake.
  5. #185
    DIY Junior Member campbell914's Avatar
    Jul 2010
    Boston
    We have just had installed three Aquia dual flush toilets as part of a whole house remodel. We love the toilets and have the Terry Love website to thank for helping us select them. However, we have one problem, all three wobble when you get up from sitting. Our contractor claims this is how this toilet is, I can't believe it's true! I called Toto and they say they haven't had this issue and recommended shims. My contractor doesn't want to deal with it and I'm not excited about shims on the floor as it would seem a cleaning issue over time. I'm just wondering if there is anyone with experience with this and what their solution was and how I could go about fixing it. (It's disconcerting to have the whole toilet move everytime you get up.)
    Thank you!
    Marcie
  6. #186
    We always give our customers shims with our install kits.
    You can't guarantee that the floor will be flat.
    A bowl should be shimmed if needed, and then caulked to the floor using something like polyseamseal.
    We like to use the clear that can be cleaned up with water.
    If the bowl has movement, you slip a shim under the bowl near the back, pinning the front of the bowl down.
    Score and snap the shim, and then caulk.
    We pick up our shims in the door department, made from plastic about six inches long with a nice gradual taper to them.
    When we or our customers install toilets, there is no movement in the bowl when done.
    I'm sure you will be able to do a better job in 30 seconds then your "handyman" could.
  7. #187
    Also note that you probably should reset the toilet with new wax. The wax isn't a spring, and once compressed, then rocked back the other direction, it will leave a gap. IF the line ever clogs up, it will leak waste out that gap, and sewer gas could always come out. It is likely small, but it is there.
  8. #188
    The Aquia uses an adapter, so it's probably rocking inside the adapter.
  9. #189
    DIY Junior Member mojitogirl's Avatar
    Aug 2010
    PA
    Default Rough - in distance from wall for TOTO Aquia
    We are installing the Toto Aquia II this weekend in a lower level that we are finishing. Fo some reason our plumber installed the rough-in at 15 inches from the wall behind it (probably because code for space on each side is 15). Since the manual reads 12 inches, are we going to have an issue with installing this toilet and do you have any suggestions?
    Thanks.
  10. #190
    The toilet will sit 3" further from the wall than 'ideal' design. If that isn't an issue for you, the toilet will work fine.
  11. #191
    Aug 2010
    PA
    Aesthetically, I am thinking this won't be that great? Anything else to consider functionally - other than the obvious?
  12. #192
    Toilets are designed to 'stand-alone'. So they could be in the middle of the floor and it would have no effect on how well they work (assuming the waste lines are installed to spec). They aren't designed, or need, to have any other support than to sit flat on the floor.
  13. #193
    Your "plumber" roughing in at 15" may have to do with floor joists.
    There is no code that says a the toilet is 15" to the back wall, most stanard rough-in's are 12"
    Code calls for 15" from center line to the side, not the back.
    Toto does make the Vespin, which can be installed with a 14" Unifit, that would pull the bowl back 2"
  14. #194
    DIY Junior Member chillpill's Avatar
    Sep 2010
    BC
    Never thought I'd say this about a toilet.
    I'm in love with this Aquia. The lines on it are amazing. The fact it's so well reviewed and loved for it's quality and reliability makes me want one for our renovation if I can find a supplier close enough (we love out in the sticks in BC, Canada). Hopefully be able to line one up at a realistic price somehow.
    Big thanks to Terry and everyone's posts, I have learned a lot reading this thread ... and learned a lot in two days on this forum.
  15. #195
    DIY Junior Member KHills's Avatar
    Oct 2010
    Redmond WA
    I want to order two Toto Aquia toilets and also want to get the SoftClose Seat. Can I order the set on Terry Love's website also??
    To order toilets in the Seattle area
