Leak on Stainless flex connection
Plumbob
My water softener is connected to my copper piping with Falcon stainless flex connectors. One is starting to leak at the 3/4" threaded connection.
What type of washer do I use to fix this? Is it a standard part? Thanks!
washer
It is a standard part for STAINLESS STEEL connectors, but not for anything else. Change the entire connector instead of stealing a washer from one.
And I will add a third Yay to replacing the connector.
Years of experience, if a connector leaks, or has been removed for any reason, throw it away.
These things take a set after being there a few years.
And the tubing stiffens up.
Connectors cost very little, and if installed new can last 20 years.
Unless they are messed with.
Then they are junk in minutes.
Plumbob
Thanks guys, I don't mind changing out the flex. I seem to remember however that the stainless variety of flex could be rebent, unlike the coppers ones.
The stainless is better for that.
But then I can buy a new stainless for less the $6 bucks.
There is only so much time I'm willing to spend on a six dollar item.
Especially when it may mean a return trip out to replace it on my dime.
