Results 1 to 7 of 7
Thread: unusual toilet tank - need info please
    DIY Junior Member
    Dec 2009
    lawton, ok
    Default unusual toilet tank - need info please
    i have a circa 1970 Eljer toilet with a built-in overflow in the tank. so my question is, what do i attach the the parts too? (i.e. the parts that usually attach to the overflow).
    thanks!,
    Kerry
    Last edited by hanleyk; 12-27-2009 at 07:47 PM. Reason: Elger, not American Standard
    Aug 2009
    South*East
    Are you sure it's American Standard? It looks more like Eljer.
    John
    DIY Junior Member
    Dec 2009
    lawton, ok
    Quote Originally Posted by johnjh2o1 View Post
    John
    You are correct John. Good call!
    i am away for the holidays and i made a bad guess that it was Am. Std. but after googleing 'Eljer', there's no doubt.
    DIY Junior Member
    Dec 2009
    lawton, ok
    Solved!!!
    after many hours of google'ing and you-tubing I have tracked down the elusive
    1976 round front Eljer Emblem, model PAT 191-697 with the old 'touch flush' built into tank overflow tube.
    now here's a flush valve that you won't see everyday...
    http://www.youtube.com/watch?v=bvfQt3mwsIc
    thanks everybody!
    Aug 2009
    South*East
    You will also need a tank to bowl gasket. It is a flat gasket made for the tank you have.
    John
    DIY Junior Member
    Dec 2009
    lawton, ok
    You will also need a tank to bowl gasket. It is a flat gasket made for the tank you have. John
    thanks john. i forgot to ask about that!
    Default gasket
    Flat with a ridge on it. The Fluidmaster #555 replacement flapper will also work, at least for a while, until the glue comes loose from the china seat. Just adjust the chain so it lifts the flapper without pulling on the mechanism.
