PlumbingZero
DIY Junior Member
My home has two baths. One bath is on the west end of the house and is right through the wall from the hot water tank. The other bath (master bath) is on the east end of the house. The bath on the west end of the house, has good pressure, and the hot water will almost instantly go from cool to hot. Also the kitchen faucets also perform normally for both pressure and temperature.
But the other bathroom, has both pressure and hot water issues as follows:
Bob
- Low Pressure – the water pressure for both hot and cold are significantly lower at all faucets
- Hot water is extremely slow to warm and never does become fully hot. In order to get the shower warmed up in the mornings, I turn on both sink faucets and the shower faucet on hot. I would estimate that it takes 3-5 minutes to warm. And even then, it is still not as warm as I would like. If I turn on just the shower (without the sink faucets) it takes forever to warm.
- Another observation, once I get in the shower, if the water is too warm (which rarely happens)…if you adjust it towards cool, then you can never adjust it back to warm up. So it is as if the shower faucet allows you to make it cooler, but not warmer.
- the master bath in question also has a large and separate bathtub. The faucets for the bathtub are fine and the hot water will scald you.
- This problem is worse (or at least seems so) in the winter when it is cold outside. Of course that could be because I don’t like my shower as hot when it is 98 outside.
Bob
